Installing a 12' A-920 throttle cable. I first wrapped the cable in the same grey heat-shrink material as all the wiring, for protection and aesthetics. I connected the cable to the throttle using the following two parts, which were provided, but you need the same parts for the other side of the cable: BALL JOINT 05-07400 CLAMP STYLE CONTROL MOUNT 10464
I followed my heater hose down to the cockpit, and clamped it right where I clamp the hose for the heater valve.
Top of engine throttle cable connection
Followed the heater hose and secured at the same place
