Project Blue Angels SeaRey
Date: 2-1-2013
Number of Hours: 3.00
Manual Reference: 17.24 - 17.25
Brief Description: Section 17, continuing work on pylon covers
So, I got the pylon angle on there right and riveted, then I needed to cut the channel for the flaps arm movement. I found that a regular Sharpie pen just about fits perfect in there to make the mark, while driving the flaps through their complete motion. I used a 1" wood hole drill bit at each extreme to make the holes, then snipped away the material in between. I'm not really happy with how it turned out, my original cut was one inch, but by the time I smoothed out all the rough edges, the channel ended up being wider than I wanted. It will work great, but it’s simply aesthetics. I’ll find a some molding to put around it and make it look nicer.
The right way, angle facing outwards.
Marking to cut channel for flaps
Hole too large for my liking, but I'll fix.
