Pauls Searey
Searey
Instrument panel
9-13-2009
PH
instrument panel construction
Made instrument panel from 2mm ally sheet 1200mm x 290mm. Had the local machine shop bend the sheet to the right angle then placed against nose deck, marked it and cut to shape with angle grinder. Finished off edges with file.
1200mm x 290mm ally sheet
angles added and cut to size
in place on nose deck
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
