Pauls Searey
Searey
Instrument panel
12-22-2009
PH
transponder antenna ground plane
Made up ground plane for XPNDR antenna. Mounted it as far forward as possible to keep max distance from crew. Shape is irregular due to clearance for toolbox lid.
XPNDR antenna mounted on ground plane
ground plane attached to nose deck
with coax connected and ground wire attached.
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
