Pauls Searey
Searey
stabiliser & elevato
8-1-2009
PH
extra rib and bushes in elevators
Added bushes to tube ends of elevators for anti crush and to seal tubes as not fitting drain grommets to rear control surfaces.. Extra long one fitted to bush elevator horn attach hole
nylon bush up to elevator horn attach hole
bush to leading edge attach point
extra rib in elevators
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
