Pauls Searey
Searey
stabiliser & elevato
8-1-2009
PH
nylon bush inserts in stabs
Added nylon bushes to both stabs at all 3 tube ends for extra strength and to seal tubes as no drain grommets will be fitted.. Also added bush to where the stay wires bolt through the outer stab for extra strength.
before insertion
bush in place in stab trailing edge
bush in place in stab leading edge
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
