Pauls Searey
Searey
stabiliser & elevato
8-1-2009
PH
extra rib in stabiliser
Added a diagonal rib from hinge nutplate to leading edge in both stabs as this area gets punished on take-off on water.
extra rib in stabs
marine sicaflex used to bush and hold rib in place over hinge nutplate
rib shaped to inner leading edge
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
