Pauls Searey
Searey
Fabric covering
7-18-2009
Poly-Fiber
1st coat Poly-Brush ailerons
Brushed the 1st coat of Poly-Brush on both ailerons. I thought it would be quicker if I did both ailerons at once. Once dried 2" finishing tape was applied to ends and trailing edge then 3" tape to leading edge.
1st coat Poly-Brush
finishing tape applied
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
