Pauls Searey
Searey
Fabric covering
7-16-2009
Poly-Fiber
covering starboard aileron
Applied fabric tape to sharp edges of aileron and glued fabric to leading edge. Wrapped the fabric around the trailing edge and back to the leading edge and glued. Glued down fabric on end caps and ironed fabric to tightness. Looks good.
prior to ironing
after ironing
after ironing
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
