Pauls Searey
Searey
Ailerons
4-29-2009
Searey Australia
bushing aileron leading/trailing edges
Inserted nylon bushes in leading edges and solid alloy bushes in trailing edges of both ailerons.
nylon bush in leading edge
35mm alloy bush
alloy bush inserted in trailing edge
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
