Pauls Searey
Searey
Searey Aus
fitting starboard wing trusses
Fitted first 3 trusses to starboard wing. Filed top rib end of compression tubes to wrap around rib instead of flat on round surface. Used marine Sicaflex under all attach points and ardrox on all rivets.
truss #2
trailing edge rib support bracket
leading edge rib support bracket
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
