Pauls Searey
Searey
Flaps
4-28-2009
Searey Australia
bushing flap leading/trailing edges & horn bracket
Added nylon bushes to inside leading edges and solid alloy bushes to trailing edges of both flaps.
Also drilled 3/16" holes in leading and trailing edges 28mm in from the ends on both flaps for mounting of flap horn brackets
nylon bush in leading edge tube
100mm solid alloy rod
rod inserted in trailing edge tube.
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
