Pauls Searey
Searey
Turtle Deck
10-11-2008
PH
upper turtle deck supports
Added alloy angle to upper turtle deck where diagonal root tube goes through for 2 reasons......
1. to fill cut out where too much material was taken out so that there is material to rivet side covers to
and
2. for extra support for diagonal root tube angle brackets where turtle deck attaches with bolts
L & R brackets
LH bracket
attached to underneath turtle deck
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
