Pauls Searey
Searey
Vertical fin & stabi
7-20-2009
PH
trusses in vertical fin
Added a truss and extra ribs to vertical fin to keep the edges straight when covering and to add some overall strength as the fin takes a lot of hammering from the prop.
trusses and ribs in place
front of rib shaped to curve of leading edge
rib shaped
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
video camera
Weight & Balance
Windshield & sliding
118
