Pauls Searey
Searey
Landing gear
8-27-2008
PH
bungeee cord adjust
Adjusted bungee cord tension as found that the tailwheel was hanging down off the boom tube slightly so added more tension. Also added plasitic tubing around bungee where threaded through tie off points to reduce possible wear of cord.
bungee adjusted and tied off
plastic tubing around LH attach point
plastic tubing around RH attach point
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
