Pauls Searey
Searey
Landing gear
8-13-2008
PH
tailwheel tyre rest
Made up tailwheel tyre rest so that the tyre doesn't squash the retraction cable when in retracted position. Attached with 4 x 5/32 stainless steel rivets for extra strength as it will take a beating over time.
tailwheel tyre rest etch primed
tailwheel extended
tailwheel retracted
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
