Pauls Searey
Date:  7-19-2009
Number of Hours:  3.00
Manual Reference:  PA
Brief Description:  double checking all controls surfaces before cover
As I had built the control surfaces and added a 3rd hinge to the elevators, stabs, vertical fin & rudder many months ago I went over all of them to make sure they had been constructed thoroughly. I added the wooden fillers to the inner end of the stabilisers, riveted on the support straps to the stabs and elevators, checked the tightness of all bolts, shaped the rib ends to the trailing edges and cleaned them ready for covering.
support strap riveted
ribs shaped
ribs shaped
doubled up hinge fitted to stabs
