Pauls Searey
Date:  6-24-2009
Manual Reference:  Poly-Fiber
Brief Description:  drain grommets
Attched drain grommets at lowest point on each rib with Poly-Tak and ironed into shape of trailing edge. Made hole with soldering iron before attaching. Applied doily over the top
grommet before doily
grommet with doily
grommet with doily
waste fabric was attached to a board and ironed before the doily's were cut out for grommets.
