Fitted rib trusses to port wing over 1 week as each one takes 1 hour to fit including making up rib compression tubes in centre and leading & trailing edges. . Filed top rib end of compression tubes to wrap around rib instead of flat on round surface. Used marine Sicaflex under all attach points and ardrox on all rivets.
