Pauls Searey
Searey
PH
Boom tube cover inspection covers
Fitted left and right inspection covers to boom tube covers so that the rudder pulleys and cables can be inspected prior to each flight and also for ease of inspection and maintenance of transom area.
Used cad plated camlocks for fasteners.
LH side inspection hole
RH side with support plate in place
LH side finished
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
