Pauls Searey
Date:  12-6-2008
Manual Reference:  Searey Australia
Brief Description:  wiring/fuel line tubes
Fitted 2 x PVC tubes from turtle deck to side cover angles so that I can run the fuel line and throttle cables through the forward tube and the wiring throughthe rear tube.
Sealed the wiring tubes, rear diagonal, diagonal and forward vertical root rubes with paintable silicone.
tubes through turtle deck
attached to side cover angles
