Pauls Searey
Searey
bolting frame into hull
Finally bolted frame into hull. Sealed all bolt holes with silicone sealer to ensure no egress of water into foam between stringers. Used SS bolts except for channel bracket bolts. Channel bracket bolts used are AN4-20a's.
left hand stringer with frame mounted
right hand stringer with frame mounted
forward stringers with frame mounted
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
