Pauls Searey
Date:  3-28-2008
Manual Reference:  PH
Brief Description:  actuator mounting bracket support mod
Manufactured and fitted support bars for upper actuator mounting brackets. Load will now be transferred by pushing and pulling actuators against each other when gear is being raised or lowered instead of loading up mounting brackets and fixing bolts on upper bulkhead. Coated support bars with etch primer, coated all surfaces liberally with Ardrox, including rivets, and riveted into position.
support brackets
support brackets
support brackets
support brackets
support brackets
support brackets
