Pauls Searey
Searey
PH
gap seals rudder and elevators
Fitted gap seals to rudder and elevators. Used same method as flaps and ailerons ie gap seal under hinges and fastened with silicone sealer to the leading edges.
rudder gap seal
left hand elevator gap seal
right elevator fitted to right stab
Searey Home
1118
Ailerons
Boom
Brakes
Bulkhead
Cockpit
Corrosion proofing
Crate Delivery
Crate Delivery & tra
Electrics
Fabric covering
Flaps
Floats & struts
Forward cockpit
Fuel system
Gap seals
Hinges
Hull
Inspection
Instrument panel
Instrument panel wir
Interior trim
Labels
Labels & data plates
Landing gear
Lighting
Marine
Nose Deck
Paintwork
Pitot
Pitot/static system
Root support
rudder, stabiliser &
Seat belts
Side covers
stabiliser & elevato
Throttle cables
Trim
Turtle Deck
Tyres & wheels
Vertical fin
Vertical fin & stabi
video camera
Weight & Balance
Windshield & sliding
118
