Scott's Aircraft Build Logs
Date:  10-16-2020
Number of Hours:  5.00
Brief Description:  Bottom skin layout
Spent several hours determining bottom skin layout. All ready to cut a 4' X 12' sheet of 0.025 aluminum when I discovered I should be using 0.020. You might say "What difference does 0.005 make?" Well it would mean the left wing was over 2 pounds heavier than the right wing. It wouldn't fly straight. Ordered the 0.020
