Finished drilling the fuel bay skin cover screw holes. Spent a bit of time laying out the rivet line for the bottom skins to rivet to the aft spar. This is the last row of rivets to get laid out. You can see the string in the lower portion of the image. With that pulled incrediby tight I marked a line on the skins. Now I need to mark the actual rivet locations with a rivet fan.
