Well again my house project has taken up too much of my time and my RV-7 needed its annual condition inspection completed. Those two projects, and others, kept me from working on the Bearhawk. Now I can get back at the Bearhawk.
I measured and re-measured to make sure the wing is straight. Satisified it was as straight as it would ever be I drilled the skins to the forward spar. This is an irreversable action, once the spars are drilled that is it. The wing is set.
I also started drilling the fuel tank cover to the wing. I need to fabricate the lower skin from the cover to the aft spar.
