Scott's Aircraft Build Logs
Date:  4-9-2021
Number of Hours:  8.00
Brief Description:  Wing skins, starting again
Well again my house project has taken up too much of my time and my RV-7 needed its annual condition inspection completed. Those two projects, and others, kept me from working on the Bearhawk. Now I can get back at the Bearhawk.
I measured and re-measured to make sure the wing is straight. Satisified it was as straight as it would ever be I drilled the skins to the forward spar. This is an irreversable action, once the spars are drilled that is it. The wing is set.
I also started drilling the fuel tank cover to the wing. I need to fabricate the lower skin from the cover to the aft spar.
Wing top with forward spar drilled
Wing bottom forward spar drilled
Fuel tank cover
Fuel tank cover
