Scott's Aircraft Build Logs
Date:  12-1-2020
Number of Hours:  5.00
Brief Description:  Most inboard skin
Before I can drill the fuel tank screw locations I need two more skins installed, both will have nutplates riveted to them. The most inboard skin and the bottom aft skin covering the area of the false spar to the aft spar. In the second image I have two rags laying on the false spar, so you will know what I am talking about.
The inboard skin wraps around the entire wing unlike the other skins. I cut a 12' slice of 8.5" 0.032 by hand and am quite happy how it came out. A little of the Zen of the moment getting it cut straight. Then it was just a matter of rivet layouts and drilling / clecoing rivet holes.
You might notice the outboard portion of the bottom skin is not drilled. That has to be done in conjunction with the tank bay cover.
Top skin
Top skin
Bottom skin
Bottom skin
