Scott's Aircraft Build Logs
Date:  10-2-2020
Number of Hours:  5.00
Brief Description:  Pitot tube
Installed pitot tube in leading edge. The pitot tube has integrated static holes which should mean I do not need static holes in the fuselage. The tube is attached to the spar and secured to a nose rib by aluminum Z bracket.
