Started skinning the wings. Each skin needs to be bent slightly to fit around the nose ribs at the leading edge. The process I copied uses an 1 1/2" schedule 40 PVC pipe and a shop vacuum. By sealing the sides and using the shop vac I was able to bend an appropriate radius.
