Scott's Aircraft Build Logs
Date:  8-8-2020
Number of Hours:  5.00
Brief Description:  Wing skins
Started skinning the wings. Each skin needs to be bent slightly to fit around the nose ribs at the leading edge. The process I copied uses an 1 1/2" schedule 40 PVC pipe and a shop vacuum. By sealing the sides and using the shop vac I was able to bend an appropriate radius.
image rotated 90 degrees
