Scott's Aircraft Build Logs
Date:  5-8-2019
Number of Hours:  1.00
Brief Description:  A little more progress
Today was a day of interruptions, only worked for an hour or so. Riveted the flanges onto ribs 9 and 10 (image 1) for the wing fence. A friend had the correct size rivets so I finished that riveting work, no pun intended. I need to install nutplates, that can wait.
I also riveted the flange at the root rib (images 2 and 3). One was not set properly so I drilled it out and set a new rivet. Making steady progress.
