Scott's Aircraft Build Logs
Date:  1-12-2019
Number of Hours:  0.10
Brief Description:  Flying
First things first. Took the RV up for a stroll in the sky. As the engine cools after a flight condensation occurs so it is better for engine longivity to heat it up and cook away internal moisture. I know, when I get back it will cool down and the process repeats. Just more reasons to fly.
if you look at the lower left of the screen in the photo you will see 198 knots ground speed (GS.) That is 227 MPH.
