Went to the hangar and pulled the balls and wooden shelf to check the inside. A little had squeezed out of the bottom edge of the canopy. I laid a bead down around the inside bottom edge just to complete the installation. Then removed all the tape and protective plastic on the inside and outside.
The rest of the time was spent cleaning up around the canopy. Without the activator and primer the Sikaflex does not adhere. So I could wipe off or rub off any small smears created by removing the tape. The toughest part was removing the residual adhesive from the protective plastic. That stuff wants to stay.
