Working on getting the aircraft ready for the Sikaflex process. Put the canopy back on to check the masking tape alignment. I want to ensure when the tape is pulled off there is just a thin line of Sikaflex visable.
I scuffed all the metal edges on the canopy frame and started masking off the interior of the aircraft. The primer is very runny and etches very quickly, so you have to protect the interior surface from the primer. The adhesive is very thick, so it won't be an issue.
I still need to scuff the canopy and finish masking the aircraft.
