Aft several hours and days of work the canopy is finally coming together. You can see the left and right sides are almost flush, about 1/16" or less gap. You can also see the skin gap on both sides, due to installing the canopy reinforcement kit. After I install the struts and finish drilling the frame and skin I will address this issue. I know it will move again next time the canopy is removed.
