Scott's Aircraft Build Logs
Date:  8-7-2014
Number of Hours:  6.00
Brief Description:  Final trimming
Continued on the task of trimming and fitting the forward canopy and aft window. After several iterations of canopy on, check fit, mark for trimming, remove canopy, trim, sand and replace canopy; I believe I am very close to a final fit.
I had my wife, the rivetor and seamstress with a great eye for straight lines, come over. She checked my work for finish and alignment. Always good to have another opinion.
Also made the large trim on the aft window. Still alot to take off as you can see in image three.
Left side, just a little bit more
Right side is done
Right side is done
More trimming on the aft window
