Got two hours to work on the canopy today. I marked a few areas on the front that needed minor trimming and measured several locations along the front to ensure symmetry. Pulled it off and went to work trimming and sanding. I also worked on a slight bevel along the front of the canopy.
While I waited for help to put the canopy back on the aircraft I opened up the "ears" on both sides. With help I put the canopy back on for another fitting. The "ears" need more work and I am ready to mark the sides for a final trim. After that trim the front will only need some slight work for a better fit.
