Continued work on avionics and the associated wiring. All the wing wiring has been pulled into the aircraft, the pitot / static system is connected, starting to zip tie the wiring bundles and made room for the radio stack wiring harness. The images of the wiring harness hole makes it look out of round, but I used a Greenlee punch. I believe it is the aligator protective strip that is not fully pushed down that makes it look that way.
