Scott's Aircraft Build Logs
Date:  8-12-2016
Number of Hours:  4.00
Brief Description:  More system work
Wired up more engine systems including the fuel flow transducer. To eliminate potential chaffing I had to add a few Adel clamps. Two of those clamps required some means of attachment so I fabricated to attaching points.
I had purchased a two port USB charging device. I ultimately plan on purchasing a second AFS 5500 screen but in the mean time I will have my iPad attached to the panel. This will allow my iPad and phone to charge while in flight (no data, just charging.) This is installed in the lower right corner of the instrument panel.
