Scott's Aircraft Build Logs
Date:  4-30-2016
Number of Hours:  3.00
Brief Description:  Wiring - 02
Image one shows the left side after I ran some of the wiring. The wires coming from the left side of the engine and through the firewall pass through join the bundle coming out through the rib.. You can see the Adel clamp. Eventually this wil get laced together so all the wiring supports each other. The pass through provides some support, the Adel clamp does and under the subpanel is another Adel clamp You might make it out on the left edge of image three.
Image two shows the growing wire bundle. Also visible is the forest of tabs where all the grounding wires will be collected. Just below it you can see one of the conduits with wiring coming out the top. I believe I will end up with a 1" bundle by the time this is done.
Left side of aircraft
Looking down from the right side
Looking forward through the instrument panel
