Scott's Aircraft Build Logs
Date:  11-21-2015
Number of Hours:  5.00
Brief Description:  Finished up the pre-wiring panel work
The panel has a rib that runs across the top. As the rivets are flush I counter-sunk the panel and then riveted the rib in place. I installed most of the switches and the auto-pilot panels in preparation for wiring. Several tasks still needed in support of finishing the panel; I need to install the quarter turn fastener for the fuse panel, the sub-panel needs to cut for the radios and the engine control panels need to be installed. After all that is done I will pull the panel, prime and paint it.
