Drilled holes for support for the wiring coming from the baggage compartment light. I wanted to make sure the wiring stayed away from the flight controls. Run the wiring all the way to the top of the firewall.
More wiring will run down this support. The Dynon GPS antenna will be on the aft skin directly above this run.
