The new crimper showed up yesterday so I was able to work on wiring all day today. First task was to crimp connectors on the autopilot terminal block at the right wing (under the right seat.) The coiled yellow wire is for the disconnect switch that will be mounted on the pilot's stick.
Next task was to cut the network cable to the correct length, crimp the connectors and install the DB9. Image two show the cable attached to the forward network hub. This cable runs to the aft hub where the servos and the ADAHRS are connected. Image three shows a small service loop forward of the forward hub. There is more cable to that needs to be included in that loop.
