Brief Description: More pitot / static, autopilot and compressor work
I did not like the way the pitot and AOA lines were hanging in the aft portion of the aircraft. I fabricated a small angle with a platenut and riveted that to the J-channel. Using Adel clamps (inmage one) I secured the lines.
I put the servo connection together. I was waiting for the clamping tool to arrive. This will connect to the network hub. I spoke to Dynon about running the power lines on the network and Tech Support said that would not work. The three lines (yellow, red and black) are for the power and interrupt switch. They need to run separately from the network. Of course, the cable I needed was at home. I will fix that tomorrow.
My compressor has not been working properly for some time. I have been babying it along, but it needed to be fixed. I had to order a new regulator (the old one leaked) and a new circuit breaker. Now it is back to running properly.
