Started the initial condition inspection as I get ready for the Airworthiness Certificate inspection. One of the remaining tasks was weighing the aircraft. The first two images were taken as I worked on determining level for the aircraft. The cowling was off for that process but on during the weighing. I had help from several friends; Chris, Lori and Larry as the aircraft was weighed. It weighs 1066 lb, which is light by RV standards.
If I choose to paint the aircraft that will add 30 lbs, bringing it closer to the 1100+ that most weigh.
