After priming all the components I set about riveting things together. In image one you can see three AN470-4 rivets in front of the J channel and two of the four blind rivets behind the J-channel. By adding this slight extension I gain about an inch from the side skin which leaves extra room for the rudder cable behind it. Image two shows the routing of the ELT antenna cable.
