Last task for the week was to get the gear legs on the engine mount. I knew the firewall interfered with the legs so I had already trimmed it a little already. I used an engine lift to lift the aircraft up high enough to get the legs in the mount. The left side had enough clearance but the right side did not. I pulled the engine mount and used my dremel to take more material out. Image one is a shot of the left leg, don't know why I shot it instead of the right.
The other two images are of the Van's wiring harness. It is laid out on two shelves to make it easier to strip out specific wires.
