Scott's Aircraft Build Logs
Date:  11-25-2014
Number of Hours:  2.50
Brief Description:  More odds and ends - 01
Completed more small tasks that need to get done. I noticed I installed bolts connected the horizontal stabilizer aft spar to the fuselage incorrectly. Image one shows them installed correctly with the heads forward. The four other bolts are installed as per plans with the heads aft.
I installed the gascolator doubler on the fire wall. This was a lot easier with the skins off the aircraft.
Bolts installed correctly
Gascolator doubler
Gascolator doubler
